Hello Pitstoppers,
I have a little issue that I'm having a hard time working out.  We currently use Quite Imposing for our imposition however, we would like to switch to using Impostrip because it allows for greater automation.  The problem is that in several of our workflows (we use Esko Automation Engine for our workflow software) we rely on the "Set Trim and Bleed Box to Marks" to define the trim box after imposition.
The problem I am having is that "Set Trim and Bleed Box to Marks" works perfectly with jobs imposed from QuiteImposing but doesn't work for Impostrip imposed files.  Both have reg marks set to Registration but for some reason, pitstop can seem to recognize the marks in the Impostrip built files.
Here is a link to two dummy files for somebody smarter than me to try and mess with.
https://www.dropbox.com/sh/ph9rdn0b8dxe ... YjXca?dl=0
If somebody can tell me why "Set Trim and Bleed Box to Marks" is not working on the Impostrip file I would be super stoked.
Thank you in advance.
Bob
						Quite Imposing vs. ImpoStrip
Re: Quite Imposing vs. ImpoStrip
Hello Bob,
If you need further help with your issue, please feel free to contact Enfocus Support:
https://www.enfocus.com/en/support/cont ... tact-hours
Since you are obviously also an Esko customer you can also contact Esko support:
https://www.esko.com/en/support/contactsupport
