Switch: Search for Fontname and take down
senghaas
Hi switch colleagues,.
I have a current problem for switch. We should filter out the fonts (types) used in a PDF workflow and perform the findings in a table. At best, with the number of hits found.
What we have so far is a Callas engine decomposed the PDF in an XML, where the fonts are listed clear. Now it comes to this XML to the path "document/resources/fonts/name" to browse and list the fields in a text file or Excel spreadsheet.
Has anyone of you an idea how you can accomplish this? Do I already need a complex script? I am grateful for ideas in the advance!
Thank you very much! Jurgen
loicaigon
Hi Jurgen,
If you have the metadata module, you can route jobs depending on the callas log and specifically what's inside.
Not much but hopes that helps.
