I have EDL file (Enfocus Design Layout) that works fine in Pitstop.
I want to use this file automatically in Switch/Pitstop Server combo but can not figure out how?
Configurator offers only Actions and Preflight profiles to be used.
How to use Design Layout in Switch with Pitstop?
abailescollins
There is a way to do this, but it's a bit convoluted.
Firstly you need the Global Change 'Apply Page Boxes"
This allows you to import and EDL and save a Global Change.
Then you need to save that Global Change as an Action List. That's available under the little cog on the top right hand corner of the Global Change panel.
Then you can import that Action Lists into PitStop Server.
andrewb@enfocus.com
andrewb@enfocus.com
