Script expression - If - Else
Chrissigge
Hello, I want to use Script Expression but I have no knowledge about Java,
I think what I want is pretty simple.
if pages in pdf are odd than ....
else if pages in pdf are even than....
Can somebody help me out with this simple task?
Thank you very much.
sander
var theVar = job.getVariableAsNumber("[Stats.NumberOfPages]");
if (theVar % 2 == 0 ) {
	s.log(3, "Even!");
} else {
	s.log(3, "Odd!");
Something like this?
%2 checks if theVar is dividable by 2, if so it's even, else odd ;)
Part of my playground:
jan_suhr
You can solve this without scripting too.
I guess you want to sort even or odd pages from a PDF and do different things with them.
If you first split the PDF in Switch and UnGroup the folder the pages end up in you have files with a suffix of the page numbers.
On the connection out of the folder you have a condition [Job.NameProper:After="_"] that Matches ^\d*[13579]$
For even values you change to ^\d*[02468]$
Screenshot 2017-07-04 14.46.44.jpg (133.52 KiB) Viewed 107992 times
Jan Suhr
Color Consult AB
Sweden
Check out my apps
Chrissigge
jan_suhr wrote:You can solve this without scripting too.
Hi Jan, that solution was not possible in this case, Im using a third party configurator and the only way is here to work with script expressions.
But thank you for your help. :)
Chrissigge
	s.log(3, "Even!");
} else {
	s.log(3, "Odd!");
Hi sander, exactly like that :D . Thank you.
Do you personaly write these expressions directly in the script expression window or is there a better more elegant way to write scripts like that?
sander
Most of the script expressions only hold a few lines of code and I write these from within the script expression window itself. In practice: copy, paste and adjust :P
If the script is bigger then I use Switch Scripter, however I barely use these as a script expression.
