Is there a way to create job in InDesign Smartstream Create Job Script using javascript?
SmartStream> CreateJob ( image below )
https://ibb.co/ggcQ7F
Thank you in advance
Re: InDesign Smartstream Create Job Script
I did some findings while using Switch the last years, I'm not into InDesign javascript but I bet it can help you to get in the right direction.
"I think":
In the folder %userprofile%\Documents\Adobe Scripts there's a jsx file created when a new job arrives at the configurator.
impp.jsx in that folder (theres a vdp.jsx too):
So it looks like you need to supply a xml for this, if you are quick you can catch the temporary xml when it enters the configurator, I did for you:
So if you can create a correct SmartStream xml file you can javascript create job
I would look for a xml file in a temporary location when you hit create job, maybe you don't have to read the manual then
Hope it helps,
Sander
							"I think":
#target InDesign-11.064
app.createJob("C:/Users/admin-wihabo/AppData/Roaming/SmartStream Configurators/IMPP/MB_404-1119-tempXML.xml");
<ScriptParams version="SmartStream Designer v5.5">
	<InputPDFFiles>
		<File path="D:\SwitchData\backing\4) PDF\automanaged\Asset#2\_1C567_MB_404-1119.pdf"/>
	</InputPDFFiles>
	<Parameter ParamName="ImpositionTemplateFile" ParamValue="C:\Users\admin-wihabo\Documents\SmartStream Designer\Imposition\210x100_4x_duplex.impp"/>
	<Parameter ParamName="CropTo" ParamValue="0"/>
	<Parameter ParamName="JobOutputDir" ParamValue="C:\Users\admin-wihabo\AppData\Roaming/SmartStream Configurators/IMPP/"/>
	<Parameter ParamName="JobOutputName" ParamValue="MB_404-1119-imposed"/>
	<Parameter ParamName="JobOutputFormat" ParamValue="PDF"/>
	<Parameter ParamName="JobOutputType" ParamValue="Rich"/>
	<Parameter ParamName="PDFPreset" ParamValue="Wihabo druk pms geen snijtekens"/>
	<Parameter ParamName="PaperSize" ParamValue="458x318"/>
	<Parameter ParamName="JobStatusFile" ParamValue="C:\Users\admin-wihabo\AppData\Roaming/SmartStream Configurators/IMPP/MB_404-1119.xml"/>
</ScriptParams>
Hope it helps,
Sander
Part of my playground:
Thanks for the info, I will have a test for this
Sorry but Im just a novice in js InDesign and I can't convert this into Indesign js but still thanks for looking into it
That's basically what the HP SmartStream Designer VDP Configurator does.  Is there something you want to do that can't be handled by the configurator?
This is how it goes.
Everyday, I'm processing for about 20 to 30 projects that consist VDP on it.
it is like SmartStream> CreateJob> choose jlyt:Last to first then SmartStream> CreateJob> choose pdf
I'm hoping to automate the process using script if it is doable
thank you
thank you
