Hello all,
I've got a problem with converting PDF to JPG with ImageMagick (and Ghostscript)
There is a flow with the "execute command". The program that is used is convert from ImageMagick, simply using the "%1" "%2" arguments.
output File Extension is jpg.
Now every PNG, TIF or any other image is running perfect through this flow.
But any PDF File is send to null by switch...
Using an Switch Script is also NOT working!
The same command manual used in the terminal is working!
Does anyone have a solution for that?
Or have an alternative tool (exept Acrobat or SIPS) to get good quality jpgs from PDFs?
Thanks in advance!
Michael
PDF to JPEG with ImageMagick and Ghostscript
Hello, if you are using "Execute command" configurator then you should be able to select one of the Output properties that supports "Copy input job" == yes option.
Hello Dwight,
thanks for your answer, I've tried any possible options in the "Execute command" and always the same error.
Job send to null...
With a similar SwitchScript in JavaScript an error occures, the gs command can't find the file to convert.
But from the terminal with the same arguments the converting works fine.
Regards,
Michael
Job send to null...
Regards,
Michael
I know it will work with a JS script because I've done it many times. You have to create a job folder, move the PDF and JPEG file into it and then call SendToSingle() with the job folder.
OK, then I think I'll check the ImageMagick Installation first.
Maybe there is something broken....
Thanks for your help!
Michael
Michael
Hello again.
I'm sorry, but I didn't get it.
In my script, the ImageMagick wont't work, I always get an error "gs: can't find the image..."
So Ghostscript won't get thr image from ImageMagick, because switch already runs in an error?
So here's my script, maybe someone can help...
Thanks!!!!
var theProcessPath = s.getPropertyValue( "argProcessPath" );
var thePixelWidth = s.getPropertyValue( "argPixelWidth" );
var theOutputFormat = s.getPropertyValue( "argOutputFormat" );
var theArguments = new Array();
// var theTempPath = job.createPathWithName( job.getNameProper() );
var theOutputFile = "/path_without_spaces" + job.getNameProper() + "." + theOutputFormat;
theArguments.push( theProcessPath );
theArguments.push( job.getPath() );
theArguments.push( theOutputFile );
theArgumentsString = theArguments.join(" ");
var returnCode = Process.execute( theArgumentsString );
job.log (2, theArgumentsString );
if( Process.stderr != "" ) {
job.log( 3, "Prozess-Fehler: " + Process.stderr );
if( new File( theOutputFile ).exists ) {
job.sendToSingle( theOutputFile );
} else {
job.log(3, "IM-Datei existiert nicht!: " + Process.stderr );
Thanks!!!!
} else {
Hi Michael,
Can you still try execute command with GhostScript? Here is sample settings which are working for me.
Command or Path: C:Program Filesgsgs9.06bingswin32c.exe
Arguments: -dSAFER -dBATCH -dNOPAUSE -r300 -dJPEGQ=80 -dDOINTERPOLATE -dMaxBitmap=500000000 -dUseTrimBox -dGraphicsAlphaBits=4 -dTextAlphaBits=4 -sDEVICE=jpeg -o "%2" "%1"
Output: File at path
Copy input job: No
Output extension: JPEG (*.jpg; *.jpeg)
Fail if exit code is: Nonzero
Have you done some conversions with ImageMagic from png or tiff to jpg? Can you give some sample settings?
-Robert
Copy input job: No
-Robert
Hi Robert,
thanks for your answer, this gives me a temporary solution for my problem.
I'll use your direkt command for PDF Files now, thanks!
With ImageMagick I'm using
Arguments: "%1" -compress JPEG -quality 99 "%2"
The rest as for Ghostscript...
Regards,
Michael
Regards,
Michael
Hello, just use the arguments array directly instead of combining them into a string.
mkis wrote: var theArguments = new Array();
var returnCode = Process.execute( theArguments );
Re: PDF to JPEG with ImageMagick and Ghostscript
As I was searching for something else I stumbled over this very old post and I saw that it does not have a conclusive answer and I thought I would add it now as it is still relevant today and possibly for other applications than Imagemagick too.
When running "Execute command" the application is not run in the same environment as when you are running it in Terminal/Command prompt so you cannot rely on all environment variables (esp. PATH) to be the same, even to be defined. And that is where the problem lies with Imagemagick/Ghostscript. Imagemagick calls Ghostscript by simply calling "gs" or "gsc" and when the PATH variable does not include the location of Ghostscript it will fail.
Solution: do not run Imagemagick directly in "Execute command", but run a shell script/BAT file so you can set the PATH variable correctly before running Imagemagick.
You can try setting the PATH variable for Ghostscript in a shell script before running ImageMagick. This should fix the issue where Ghostscript isn't found. Also, for quick JPEG compression, you can use online jpeg compressor tool to compress your images without losing quality.
