Escape
lohbrand
we have tis Script:
var _testString = "Test&Test Test+Test=Test-Test";
_testString = escape(_testString);
and this one:
_testString = _testString.replace("+", "%2B");
the log say something like this:
Test/var/folders/ff/ffKQdrvpHF4CpidNJmasOU+++TY/-Tmp-/FixtureTest14/inFolder26Test/var/folders/ff/ffKQdrvpHF4CpidNJmasOU+++TY/-Tmp-/FixtureTest14/inFolder20Test+TestDTest-Test
Who need the Folder? Has anybody a tip?
Thanks Lohbrandt
lohbrand
Is there anybody from Enfocus, who can answer questions?
TOP CONTRIBUTOR
I'm a little confused. Your JS snippet doesn't involve a path at all. Did you append _testString variable to another value like job.getPath()? Did you mean to add a directory separator character, eg. '/', between inFolder and _testString?
lohbrand
thank for your post dkelly.
the script is what i post.
there is nothing else.
i dont understand the path in the log message, because there is no job.getPath() command.
rzacherl
Hello lohbrand,
based on the path I would state that you're using the Fixture (debugging) capabilities of SwitchScripter to test your script outside Switch.
Regards,
Robert
lohbrand
the same answer in the log (PowerSwitch11).
TOP CONTRIBUTOR
Is this script being used in a script expression or a scripted element?
lohbrand
in a script-element
TOP CONTRIBUTOR
I guess I don't understand your question because a scripted element would need more code that that. A jobArrived() or timerFired() function at least.
lohbrand
job.log(1,_testString);
what happend whit your engine?
lohbrand
Oke, we have a answer.
The commands log and fail will never display the char %.
Thanks.
marbledaemon
It's true.
The 's.log' and other text-related functions will treat %[number] as a wildcard parameter. As you can see here, your %2B falls in that category as %2 is treated as the job folder.
You might want to write that text to a binary file to read it.
