How To Gather File Names And Include In Email
gfloro
As part of one of my flows, I am "Assemble Job" flow element to assemble 5 PDFs into a Job. That Job is then Compressed and attached to an "Mail Send" flow.
I want to know how to [a] gather the names of the PDFs that were compressed and add them to the body of the "Mail Send".
Thanks,
Gregory
carineb
Hi Gregory,
it is possible to add a job name or other information about a job in the body of mails send by Switch. As this can be done using variables, this functionality is available in all Switch flavors. I've uploaded a sample flow that shows how to achieve this.
Gathering information about the content of a zip file however, can only be achieved using scripting and therefor is only available in PowerSwitch. You can either write such a script yourself, or have it written for you. If you need help writing your script, you can contact our Professional Services Team and they'll provide you with a quote. You can reach them at professionalservices@enfocus.com
Hope this helps you.
Kind regards,
Carine
gfloro
Carine
Thanks for the response. I am using PowerSwitch, I'll try my hand at scripting that myself. If I get stuck I'll reach out to Professional Services.
Thanks,
Gregory
Sukerti
test
gfloro
Carrie
As a follow up. Turns out the Mail Send processor actually zips the attached files and lists the contents of the zip in the email. Which is what I was looking for. I was originally using the Compress processor to create the zip prior to emailing. Problem solved.
Gregory.
