Getting the XML out of the PDF
Flow666
Post by Flow666 »
I have a PDF with XML data embedded in the file (jdf).
I can see this if i open the PDF as a text file.
It isnt visible in the metadata when i search for it.
I have tried to save the PDF in acrobat and export to XMl but thats not working (error messages).
With what application can i get the data out?
TOP CONTRIBUTOR
Post by dkelly »
Apago's PDFspy
Peter Kleinheider
Post by Peter Kleinheider »
Flow666 wrote: Hi,
Can you please provide the PDF as there are various ways to extract the JDF from the PDF to get access to the XML data.
peter[at]inpetto[dot]cc
Thx,
Peter Kleinheider
Clive Andrews
Post by Clive Andrews »
Yeah - if you can put a link to it, I'll have a look too...
Peter Kleinheider
Good afternoon,
the XML code you refer to is part of a PostScript Form XObject. I do not know of any software that extracts such PS-Parts as part of its functionality.
The only solution I know is to write a Switch Script that searches for such XML as part of PS Form XObjects and save it in a separate file or attach it as dataset.
If that is something you are interested in, just drop me a line on get in touch with other folks here on the list.
Cheers,
Peter
