Excluding a Folder on FTP
aoswood
We just purchased SWITCH and are attempting to create FTP checking Flow.
I have it checking a directory on the FTP every 10 minutes. Take that file uncompress it and move it to a folder on our file server. It sends an email about the files being available.
The issue I am having is there is a Directory in the FTP directory that I do not want downloaded. I created an exception in the FTP Receive but every time I start up the flow it process'es this folder. How can I get the exception to ignore this folder.
jonasy
Is the folder you want to ignore a direct subfolder of the folder you set in the "FTP Directory" setting? If so, then the following rule should do the trick:
Excluding folders named
Folder Name: FolderNameToIgnore
On levels: 1
Restriction: None
Nesting: Exclude nested subfolders as well
Kind Regards,
Jonas
