Enfocus Community • Creating new job via script
Posted: Thu Aug 06, 2015 1:57 pm
by DtM
Hello!
I was wondering if anyone could offer me some insight as to why my script is unable to create a new file and output it into my flow.
Here is the script I have written attempting to do so:
// Is invoked at regular intervals regardless of whether a new job arrived or not.
// The interval can be modified with s.setTimerInterval().
	s.log(3,'Tick.');
	var slowInterval = 600; // Number of seconds between unfruitful searches
	var fastInterval = 10; // Number of seconds between job yielding searches
	var maxLines = 10;  // Number of lines to attempt processing before requerying the database
	var select1 = "SELECT order_id, line_number, line_id, url " +
				  "FROM table_name AS tn " +
				  "LEFT JOIN other_table AS o ON o.id = tn.order_id " +
				  "WHERE tn.status = 'READY' AND o.status = 'READY' " +
				  "ORDER BY order_id, tn.line_number;"
	var jobLinkDS = new DataSource();
	jobLinkDS.connect("JL-DEV");
	var selectQuery = new Statement(jobLinkDS);
	var updateQuery = new Statement(jobLinkDS);
	selectQuery.execute(select1);
	var activeOrder = 0;
	for (i = 0; i < maxLines; i++) {
		if (selectQuery.isRowAvailable()) {
			s.setTimerInterval(fastInterval);
			selectQuery.fetchRow();
			s.log(3,'loop run ' + (i+1));
			orderID = selectQuery.getString(0);
			lineNum = selectQuery.getString(1);
			lineID = selectQuery.getString(2);
			URL = selectQuery.getString(3);
			if (activeOrder == 0) {
				activeOrder = orderID;
			} else if (activeOrder != orderID) {
				s.log(3, "New Order ID. Restarting.");
				return;
			var newFile = new File(s.createPathWithName("#" + orderID + "-#" + lineID + "(" + lineNum + ").dg"));
			s.log(3, newFile.fullName);
			var newJob = s.createNewJob(newFile.fullName);
			newJob.setPrivateData("orderID", orderID);
			newJob.setPrivateData("lineNum", lineNum);
			newJob.setPrivateData("lineID", lineID);
			newJob.setPrivateData("URL", URL);
			newJob.sendToSingle(newFile.fullName);
			var update1 = "UPDATE table_name SET status = 'IN SWITCH' WHERE line_id = " + parseInt(lineID,10);
			updateQuery.execute(update1);
		} else {
			s.setTimerInterval(slowInterval);
			return;
To summarise what the script should actually be doing:
  • Check the database to see if there is a suitable job
  • If there is, generate a dummy .dg file and attach relevant information as private data
  • Output the file into the flow, where the private data can be actioned upon
Everything seems to be working fine, except for the actual output of the file, does anyone have any idea why this might be?
Many thanks,
Dan
Re: Creating new job via script
Posted: Thu Aug 06, 2015 3:47 pm
by gabrielp
Can you try changing this:
To this:
newJob.sendToSingle(newJob.getPath());
I think sendToSingle() is expecting a job path.
Posted: Thu Aug 06, 2015 4:08 pm
by DtM
Thanks for the advice, but it doesn't make any difference unfortunately.
Posted: Thu Aug 06, 2015 5:34 pm
by gabrielp
How about this?
   s.log(3,'Tick.');
            return;
		  // Put job name in a variable for later
		  jobKey = "#" + orderID + "-#" + lineID + "(" + lineNum + ").dg";
		  // Create a new job container
		  newJob = s.createNewJob( jobKey );
		  newJobPath = newJob.createPathWithName( jobKey, false );
		  // Log
		  // Set private data
		  // Update query
		 // Send to single
         newJob.sendToSingle( newJobPath );
      } else {
         return;
Posted: Fri Aug 07, 2015 9:40 am
by DtM
It still doesn't output any files strangely.
Let's go back to basics. Ignoring all of my database and private data needs, what would be a simple way to generate a blank file and output it every iteration of timeFired?
Stripping the code you gave me back down to it's basics, something like this should work:
	fileName = "test.dg";
	newJob = s.createNewJob(fileName);
	newJobPath = newJob.createPathWithName(fileName, false)
	newJob.sendToSingle(newJobPath);
But I still don't get anything out of the script. I've double checked and I've definitely got the script outgoing connections set to one.
This is quite the mystery... :?
Posted: Fri Aug 07, 2015 11:59 am
by bens
The problem is you're not creating a file on disk.
First you create a new job:
This creates a job object in Switch, but that job is not associated to any specific file or folder. The parameter to the createNewJob function is the job's origin - it's basically just metadata recorded in the job ticket.
Then you create a temp path:
This tells Switch you want a location, somewhere in a temp folder, to create a file called "test.dg". No file is being created at this point: the call just returns a path where you can create a file.
Finally, this tell Switch to send the file at path newJobPath to the single outgoing connection. But there is no file there, remember you only asked for a path but did not create a file yet.
The shortest code to create an empty file is with the static File.write function:
File.write( newJobPath, "" );
So putting it all together, this should work:
   var fileName = "test.dg";
   var newJob = s.createNewJob(fileName);
   var newJobPath = newJob.createPathWithName(fileName, false);
Posted: Fri Aug 07, 2015 12:53 pm
by DtM
And there you have it, it's now outputting.
In the original script, I had the line:
I had assumed that this was sufficient enough to create the file, but apparently not.
Here is my full code that now works as intended:
   s.log(3,'Tick.');
            return;
        // Log
        // Set private data
       // Write the file
         File.write(newJobPath, "");
       // Send to single
       // Update query
      } else {
         return;
Thank you very much to both of you for your help. :D
Posted: Fri Aug 07, 2015 3:51 pm
by gabrielp
I also assumed it would have created an empty file, but going back and looking at my older scripts (https://github.com/dominickp/SwitchAWS/ ... ad.js#L125), I do see that I am writing to the file so that makes sense.
Thanks for the explanation, bens.
