Enfocus Community • How can i retreive an archived PDF in my flow ?
Posted: Wed Sep 02, 2015 3:21 pm
by numnational
Hy all, sorry for my bad English language.
Here is my problem.
When a pdf come in "Envois", i want to retreive and reinject in the same flow another PDF based on the same name in an another folder "Emag".
How can i make this ? Can i make in a memory the name of the pdf in "Envois" ? and how can i recall this memory to trig the pdf from "Emag"
https://www.dropbox.com/s/ip538dewm4zrv ... 9.jpg?dl=0
Thanks.
Re: How can i retreive an archived PDF in my flow ?
Posted: Wed Sep 02, 2015 4:03 pm
by gabrielp
The Inject configurator should do this for you. Just have your file pass through the Inject configurator and pickup the asset from the other folder with the same name.
Posted: Wed Sep 02, 2015 4:41 pm
by numnational
OK thanks, i try with this tool.
Thank you
Posted: Thu Sep 03, 2015 2:50 pm
by numnational
It work perfectly, thank you !!! :D
Posted: Thu Sep 03, 2015 3:57 pm
by gabrielp
numnational wrote:It work perfectly, thank you !!! :D
Good to hear! Thanks for following up.
