Enfocus Community • variable text into PDF
Posted: Tue Sep 08, 2015 4:33 pm
by abonsey
Whats the best way of adding the PDF file name to the PDF just outside the bleed box on a given page??
Re: variable text into PDF
Posted: Wed Sep 09, 2015 2:03 pm
by bens
If you have PitStop, you can use the action "Add object". Select the variable "%Current Document Name% and either position it relative to the bleed box with a negative offset, or relative to a larger box (e.g. the media box) with a nonnegative offset.
Posted: Wed Sep 09, 2015 4:09 pm
by abonsey
Thanks. Works really well.
Obvious when you know how!
