Convert Metadata field (Date) to Weekday
Posted: Fri Oct 09, 2015 2:41 pm
by lombert
It's a similar problem as the other topic "Filter on Weekday" (
http://forum.enfocus.com/viewtopic.php?f=13&t=1162). But I have a date in one xml-file in the format "yyyyMMddHHmm" (201510091437).
I want to convert that to is corresponding weekday. Eg. Friday as the example.
Can I get it to work with "Set hierarch path" it would be great.
Is it possible?
Re: Convert Metadata field (Date) to Weekday
Posted: Fri Oct 09, 2015 3:51 pm
by gabrielp
This should do it:
var getDay = function( dateString, debug )
debug = typeof debug !== 'undefined' ? debug : false;
// Pattern for parsing the string
var regex = /(\d{4})+(\d{2})+(\d{2})+(\d{2})+(\d{2})/;
regex.search(dateString);
var parsedYear = regex.cap(1);
var parsedMonth = regex.cap(2);
var parsedDay = regex.cap(3);
var parsedHour = regex.cap(4);
var parsedMinute = regex.cap(5);
// Log
if(debug == true) s.log(2, parsedYear + ', ' + parsedMonth + ', ' + parsedDay + ', ' + parsedHour + ', ' + parsedMinute);
// Convert to date
var date = new Date( parsedYear, parsedMonth, parsedDay, parsedHour, parsedMinute );
// Get the day of the week
var day = date.getDay();
// Convert day code to full day
var weekDayValues = {
1: 'Sunday',
2: 'Monday',
3: 'Tuesday',
4: 'Wednesday',
5: 'Thursday',
6: 'Friday',
7: 'Saturday'
// Return
return weekDayValues[day];
// Log
s.log(2, '201510091437 becomes: ' + getDay( '201510091437' ) );
s.log(2, '201510121437 becomes: ' + getDay( '201510121437' ) );
Posted: Mon Oct 12, 2015 9:17 am
by lombert
Thanks!
But I got Sunday what ever date I put in the first line..
"201510091437" gets Sunday
"201510121437" gets Sunday
And it's Monday here now.
Posted: Mon Oct 12, 2015 5:00 pm
by gabrielp
lombert wrote:Thanks!
I should have started with regex.cap(1) instead of regex.cap(0). I've updated the script in my original post. Let me know if it that works.
Edit: put it inside a function so you can just call getDay( '201510091437' )
Posted: Tue Oct 13, 2015 12:50 pm
by lombert
The new one gives me this;
201510121437 becomes: Sunday -> Should be Monday
201510091437 becomes: Thursday -> Should be Friday
But this may be a system thing?
In the script the week starts with Sunday, is that the normal way? In Sweden we have Monday as first day? I mean that in your american system first day is sunday and everything works, but I need to change to Monday -> Sunday?
Posted: Tue Oct 13, 2015 1:31 pm
by lombert
I'm a realy noob then it came to script..
If I change the settings to start with monday it is working correct.
But how can I now use this in my flow?
The metadata (XML) is "[Metadata.Text:Path="/order/deadline",Dataset="Xml",Model="XML"]" and I want it to be set as an variabel in "Set hierarch path" so I can set a folder with the correct weekday then the files arrives.
Posted: Tue Oct 13, 2015 3:08 pm
by gabrielp
lombert wrote:But how can I now use this in my flow?
Ok... clone this repo (or just download the .sscript file):
https://github.com/dominickp/SwitchParseDayOfWeek
Drop in a new scripting configurator and browse for that script. Then, for the "Date String" attribute, choose "Define single-line text with variables". Metadata > Text > "Path >" > Build location path, and select your element that is the timestamp. This should probably be
[Metadata.Text:Path="/order/deadline",Dataset="Xml",Model="XML"].
For the "Private Data Key" property, set that to anything you want. Let's call it "
LombertsPDKey".
Just pass your job through that script and then in your archive hierarchy, you can now use
[Job.PrivateData:Key="LombertsPDKey"] (found in Job > PrivateData within 'Define single-line text with variables') which will be the day that was parsed by the script: Thursday, for example. So just drop that in somewhere where defining your hierarchy path.
Posted: Wed Oct 14, 2015 9:46 am
by lombert
Big Thanks!
Could I send you a cake I would!
I think I can get this to work now.
Posted: Fri Feb 19, 2016 4:05 pm
by lombert
Have a new question about the same metadata field.
I have tried to check if the date is "yesterday/older" or "tomorrow/younger" in a "Defining a condition with variables", but if I set the metadata to be a "date" it will not respond.
In the manual it says the string has to be "yyyy-MM-dd.. ..", but I can't change the metadata, it came "yyyyMMdd.. .."..
An ISO 8601 formatted date/time (equivalent to format string "yyyy-MM-ddThh:mm:ss.zzz") or any portion thereof
Enter a format string in the Format argument of the variable to specify which portion of the date and/or time should take part in the comparison
For example, you may enter "yyyy-MM" for the format string and "2007-08" as the comparison value to compare year and month
Why can't Switch recognise that as an date?
