I have a flow that is creating a duplicate of the job's PDF and giving it the next Switch unique name, and I can see in the log file an entry where it is duplicating the file. But I don't see any setting where I've told it to do that or where I even would tell it to (other than the "Execute Command" I'm using but I have the "Copy Input Job" set to No). It's a basic preflight flow using PSS then it calls an AppleScript to do some Finder stuff with the file. Even if I pause the input to the script, it creates a duplicate of the output from PSS. Switch v12, PSS v13.
Thanks,
Why Getting Duplicate Files?
Re: Why Getting Duplicate Files?
No idea but if you post the flow documentation, it might help one of us in finding the problem.
How do folks typically show documentation - screen shots or...?
Flow > Document Flow, then host that .html file somewhere and link to it.rgpepper wrote:How do folks typically show documentation - screen shots or...?
