Anybody seen any problem with Uncompress element
zgabeata
I have a simple flow:
An input folder -> Uncompress -> Output folder
I set the folder for the input folder and the output folder is auto managed. Eventually more stuff would be added at the end of the workflow.
The input files are ZIP files, with 2 files inside: a PDF and a XML. The name of the ZIP, PDF and XML are the same. When I drop the ZIP in the input folder, I expect that I'll get out in the output folder the PDF and XML file. But Uncompress acts as a black hole. Stuff comes in and nothing comes out. There simply are no files or folders created in the output folder, while jobs are removed from the input folder.
As you can imagine I am frustrated. Any help would be appreciated.
rzacherl
what does the Switch log say about this? Can you please post all messages generated by Switch for a single processed ZIP file?
Regards,
Robert
