HP Digital Front End JDF Control Configurator Sending MIME
ckuhlmann
Hi All,
I'm having a hard time with sending JDF's forward as a Mime Package. Bellow you'll find the errors I'm getting. Has anyone experienced this before? Im running Switch13 and HP Digital Front End JDF Control (version 8)
Failed to run external process: java -Dlog4j.configuration=file:\C:\ProgramData\Enfocus\Switch\11\scripted-plugins\com.enfocus.HP~Digital Front End JDF Control\MimeUtil\log4j.xml -Xmx500m -classpath C:\ProgramData\Enfocus\Switch\11\scripted-plugins\com.enfocus.HP~Digital Front End JDF Control\MimeUtil\lib\* com.hp.cp.mimeUtil.MimeUtil -pack -mime C:\Users\Administrator\AppData\Roaming\SmartStream Configurators\JDF\A201504220972G860KG_redo_dx08ao_21429735210_BismarkElementary14-15FINAL_4.21.15.pdf.mjm -jmf C:\ProgramData\Enfocus\Switch\11\scripted-plugins\com.enfocus.HP~Digital Front End JDF Control\MimeUtil\SubmitQueueEntry.jmf -jdf C:\Users\Administrator\AppData\Roaming\SmartStream Configurators\JDF\A201504220972G860KG_redo_dx08ao_21429735210_BismarkElementary14-15FINAL_4.21.15.jdf -assetdir C:\Users\Administrator\AppData\Roaming\Enfocus\Switch Server\temp\14\ScriptElement\2\1
Thanks a bunch!
sander
I've seen messages in my logs saying the configurator is looking for a java runtime, which it needs to run.
Might be worth a try to install?
Part of my playground:
- HP Indigo 10k, HP Indigo 7600's (full options), Highcon Euclid III, Zünd S3
- HP Production Pro 6.0.1, HP Production Center 2.5.1 beta, Apogee 9.1, Enfocus Switch 13u1 & PitStop Server 13u2.
ckuhlmann
This was the solution and also updating the configurator to version 9.
At first it did not work, but when all else fails - reboot. And its off and running.
Thnaks
sander
Great to hear!
Reboot is the magic word haha :lol:
