I need to create a flow that disassemble a folder that has other 2 folders with files.
one folder has PDF and the other has images.
I want to merge the PDF, process the images and in the end, i need to reassemble the files/folders with the same structure.
here's the example of the input and the output folder:
input folder
[img/Volumes/check-out/aaa.png[/img]
output folder
[img]/Volumes/check-out/bbb.png[/img]
						split folders, process files and merge back again with same structure
Re: split folders, process files and merge back again with same structure
This can be done with the "Submit Hierarchy" and "Archive hierarchy" tools.
Sebastian Nafroth +++ 3f8h.net / electronic publishing
3f8h.net offers professional services and products for the graphic arts
industry.
contact details: http://www.3f8h.net/kontakt
industry.
