SFTP Download using Switch Execute Command
msierra
Has anyone successfully used the Execute Command to send args to a ssh command line utility to download files? I'm attempting with Bitvise SSH Client without success. I have no issues using cmd shell and I do understand Switch executes directly in os.
I haven't, but did you know that the standard "FTP receive" configurator supports SFTP?
msierra
I was trying with Bitvise sfptc via Execute Command and finally got it to work. However as you indicated the easiest solution is to use "FTP Receive", which supports SFTP. Thank you for replying.
Terkelsen
Switch supports SFTP but seemingly not FTPS. Any ideas that could help up- and downloading to an from a FTPS-server?
3f8h.net
You may want to build LFTP or http://curlftpfs.sourceforge.net on your windows / os x box.
Sebastian Nafroth +++ 3f8h.net / electronic publishing
3f8h.net offers professional services and products for the graphic arts
industry.
contact details: http://www.3f8h.net/kontakt
