In an xml how would I go about reversing the width and height values within a flow in switch?
I take I would need a script of some sort to achieve this?
Any takers to show me how I could incorporate into a flow in switch would be much appreciated
Cheers
Sod
Change Xml values
Re: Change Xml values
Why do you need to reverse the values?sodslaw wrote:In an xml how would I go about reversing the width and height values within a flow in switch?
There are several solutions to this, depending on what you want to do:
- If the dataset is writable, you could overwrite the dataset values
- Write the values to private data (if you can't script, use metatagger in appstore), then just overwrite them in private data as needed
- Route your flow logic so you don't need to overwrite values
Thanks for your help - will look into your suggestions
Sod
Sod
No problem. If you get stuck and can be more specific, I can give you a more specific answer. Good lucksodslaw wrote:Thanks for your help - will look into your suggestions
