Get OutputIntent of incoming PDF/X
tkittel
Hello Switch-Users,
I'd like to read the OutputIntent of incoming pdf files within a flow and add it to the job's metadata. In the user guide I haven't found anything like this.
Is this a 'known variable' of switch or what is the right keyword to search for? (if not 'output intent')
Thanks in advance!
Thomas
Switch doesn't have a mechanism for extracting the PDF/X OutputIntent profile; however, you can use Apago's PDFspy. It extracts a wide variety of metadata including the OutptutIntent profiles into XML format. There's a built-in Configurator for PDFspy in PowerSwitch.
metadata path is: "/pdfattrs/OutputIntents/v0"
Dwight Kelly
Apago, Inc.
tkittel
Hello Dwight,
thank you for this detailed informations!
Thomas
