Filter XML node by type then use IF THEN
Posted: Thu May 05, 2016 1:06 pm
by abonsey
I have an XML with multiple nodes that are "Extrinsic" and need to filter it to one node of Type 'X'. Once that has been filtered correctly I need to use IF THEN see what the variable is and then use a NEW variable further in the process.
Can this be done via scripting?
Re: Filter XML node by type then use IF THEN
Posted: Fri May 06, 2016 1:29 pm
by BuckXUK
Hi Andrew
Yes, you can do all this with scripting. You'll just need the right XPath syntax to identify your target Extrinsic node.
Posted: Fri May 06, 2016 1:41 pm
by abonsey
Hi William,
Just PM'd you with a few questions.
Andrew
Posted: Mon May 09, 2016 5:45 pm
by abonsey
Here is a sample of the XML.
How could I get the "Stock" information?
Thanks for any help
Andrew
<Request type="Order" ID="2929" Date="2016-05-03T15:28:29">
<Order Version="1.0" CartNumber=“1234” Date="2016-05-03T15:28:29">
</Order>
<Items>
<Item LineNumber="6039">
<Extrinsic Type="NameOnStationery"></Extrinsic>
<Extrinsic Type="Flat Size" ExternalId="" ExternalTypeId="">A4</Extrinsic>
<Extrinsic Type="Folding" ExternalId="" ExternalTypeId="">Roll</Extrinsic>
<Extrinsic Type="Lamination" ExternalId="" ExternalTypeId="">Not Required</Extrinsic>
<Extrinsic Type="Quantity" ExternalId="" ExternalTypeId="">200</Extrinsic>
<Extrinsic Type="Sides Printed" ExternalId="" ExternalTypeId="">Double Sided</Extrinsic>
<Extrinsic Type="Stock" ExternalId="" ExternalTypeId="">135gsm Silk</Extrinsic>
<Extrinsic Type="Turnaround" ExternalId="" ExternalTypeId="">Express (5 Bus Days)</Extrinsic>
</Item>
</Items>
</Request>
Posted: Mon May 09, 2016 6:06 pm
by gabrielp
You should be able to use the XML class within Scripter to grab that value with an XPath somewhat like this:
/Request/Items/Item/Extrinsic[@Type='Stock']
Posted: Mon May 09, 2016 6:29 pm
by abonsey
Could you clarify "XML class within scripter". I've never done anything like this before.
Andrew
Posted: Mon May 09, 2016 6:36 pm
by gabrielp
abonsey wrote:Hi,
Andrew
Do you have the scripting + XML modules? If not, we'll have to come up with a different solution.
This page in the manual gives a good overview:
http://www.enfocus.com/manuals/Develope ... sions.html
Posted: Mon May 09, 2016 6:44 pm
by abonsey
Yes I do have the scripting module.
I start with:
var dataset = job.getDataset("Xml");
var xml = new Document(dataset);
var Stock = xml.evalToString(/Request/Items/Item/Extrinsic[@Type='Stock']);
but it errors.... clearly it's wrong
Posted: Mon May 09, 2016 7:05 pm
by gabrielp
I updated the link in my last post, that copied over wrong.
Don't let it stop there. In this field, you'll hit speed bumps like this a lot. Own the problem! What's the error say? Start there.
For now, this line appears to be incorrect. evalToString() expects a string. That string can be passed as a parameter in quotes or a variable.
Probably should read:
var Stock = xml.evalToString("/Request/Items/Item/Extrinsic[@Type='Stock']");
Posted: Tue May 10, 2016 12:42 pm
by abonsey
Thanks for the help. All working great now.
Onwards and Upwards from here
Andrew
Posted: Thu May 12, 2016 3:38 pm
by abonsey
HI,
I've been looking to improve/simplify the script by using a using search/replace via dictionary/key so that the same words are replaced throughout the whole xml.
I've probably got it all wrong but here's what I've got so-far that doesn't work.
Any ideas?
// Read incoming XML
var oldXML = File.read(job.getPath(), "Windows-1252");
var oldXML = oldXML.evalToString()
// Create new XML
var newXML = job.createPathWithName(job.getName());
var newXMLcontent = oldXML.mapReplace({ 115gsm Silk: 'CD S 115', 135gsm Silk: 'CD S 135', 150gsm Silk: 'CD S 150', 170gsm Silk: 'CD S 170'})
// Replace stuff
// These properties can easily be filled via standard Switch properties, see screenshot.
// Write new XML
File.write(newXML, newXMLcontent, 'Windows-1252');
// Send newXML to next folder
job.sendToSingle(newXML);
Posted: Thu May 12, 2016 4:20 pm
by gabrielp
abonsey wrote:here's what I've got so-far that doesn't work.
What errors are you getting?
This line looks problematic. You have spaces in your object keys, which is not valid.
To make the object valid, you'd have to quote those keys:
var newXMLcontent = oldXML.mapReplace({ '115gsm Silk': 'CD S 115', '135gsm Silk': 'CD S 135', '150gsm Silk': 'CD S 150', '170gsm Silk': 'CD S 170'})
But I'm not familiar with the mapReplace method or how that is supposed to work.
