Enfocus Community • HTTP Post to send xml-file
Posted: Fri May 13, 2016 11:18 am
by lombert
I'm testing to get an status-report posted at an server and they (the other company) say that I should use HTTP Post and a xml-file to get it to work. But I think I not geting everything right. I have never used HTTP request before.
First the basic; I need to have one "file" that trigger the HTTP request, but it is not that file how is going to be send, or?
When I choose the POST-type I get to select another file, is that the file how is sent?
The company say that the xml-file just needed this;
<?xml version="1.0" encoding="iso-8859-1" ?> <updateJob>
      <jobId>3675998</jobId>
      <jobStatus>0</jobStatus>
</updateJob>
And if I set it up like the picture, I got a response that it's ok from Switch, but nothing happening at the company system;
Request type: POST
Finished status: Ok
Status code: 200
Status description: OK
Last error:
The company is going to see if they got anything on there logs, but I wondering if I thinking wrong on my side at Switch?
Re: HTTP Post to send xml-file
Posted: Fri May 13, 2016 3:14 pm
by lombert
I'v got it to work with HTTP Get. HTTP Post give me an error all the time.
<status message="missing xml tag">Error</status>
But now then I understand how it works is it easier to use HTTP Get for us.
Posted: Mon May 16, 2016 11:22 pm
by andrea mahoney
When we POST using something like curl or wget we post the xml as a quoted string to the url.
curl -d xmlstring='<?xml version="1.0" encoding="iso-8859-1" ?><updateJob><jobId>3675998</jobId><jobStatus>0</jobStatus></updateJob>' http://printer.com/External_status.asp"
Maybe instead of attaching the file you can list it using Switch Variables in the Parameters section. The Parameter would look like this with the xml in single quotes:
