Enfocus Community • Split PDF
Split PDF
Posted: Fri Aug 12, 2016 7:18 am
by Wadey77
Hi Guys,
New to all this, So please be gentle with me :roll:
Just wondering what is the best solution to Split say a 20pp PDF to give the result of two files with Pages 1,2,19,20 in one PDF and 3-18 in the other.
i.e...
Original 20pp File = 12345.pdf
End Solution = 12345_1.pdf (Pages 1,2,19,20)
End Solution = 12345_2.pdf (Pages 3-18)
I've been playing with the Split and Merge but not quite getting to the end result required,
So some pointers will be greatly appreciated.
Re: Split PDF
Posted: Fri Aug 12, 2016 12:06 pm
by Terkelsen
There might be more elegant ways to do this, but I guess this would work:
1. Use Split PDF to split the file into single pages with a suffix "_index"
2. Use Job dismantler to get all these files out of the folders created by Split PDF
3. Make two connections from this folder. One that allows only files which filenames contain _01 or _02 or_21 or _22 and set the other connection to allow "All other files".
4. You now have two folders. One containing page 1,2,21 and 22, and one with all the rest of the pages. Make an Assemble Job on each of these two folders. Set the first to assemble after 4 jobs and the other after 18 jobs.
5. Use Merge PDF to merge each of these two PDF's
6. You might have to use Rename to get exactly the filenames you want.
Re: Split PDF
Posted: Tue Aug 16, 2016 12:10 am
by Wadey77
Thank you for the response, I've gone a slightly different route but it certainly helped.
Thanks again.
Re: Split PDF
Posted: Tue Aug 16, 2016 9:11 am
The method Erik describes is correct, but it is best to use variables so it works for any number of pages. The key variables in this respect are [Switch.Calculation:...] in combination with [Stats.NumberOfPages]. You will also have to "remember" the number of pages before splitting the file. What I usually do to store such a value is to put it in the job state. All the properties of a job are propagated to jobs that are derived from it; in other words, the job states of the individual pages are the same as that of the multipage job and can be used in the Switch.Calculation.
An alternative approach is to use PitStop Server with Action Lists to remove pages. In the "Select pages" Action you can use reverse selections when selecting a page range. The selection for the first two and last two pages is: 1,2,R1,R2; for the other pages it is: 3-R3.
Re: Split PDF
Posted: Tue Aug 16, 2016 9:32 am
by lombert
freddyp wrote:An alternative approach is to use PitStop Server with Action Lists to remove pages. In the "Select pages" Action you can use reverse selections when selecting a page range. The selection for the first two and last two pages is: 1,2,R1,R2; for the other pages it is: 3-R3.
Very good to knew!! Thanks!
