Recursively scan directory functions
I had to recursively scan directories within Scripter for switch-inject-lite. Perhaps these functions may be useful to others in the future.
		// Function for recursively counting bytes within a directory
			get_recursive_byte_count = function(target_dir, entry_list){
				byte_count = 0;
				forEach(entry_list, function(file_name, index){
					type = getTargetType(target_dir + file_name);
					if(type === "dir"){
						sub_target_dir = target_dir + file_name + getDirectorySeperator(s);
						sub_dir = new Dir(sub_target_dir);
						sub_file_list = sub_dir.entryList("*", Dir.Files|Dir.Dirs|Dir.NoDotAndDotDot, Dir.Name);
						result_count = get_recursive_byte_count(sub_target_dir, sub_file_list);
					} else if(type === "file"){
						fs = new FileStatistics(target_dir + file_name);
						byte_count += fs.getByteCount();
				return byte_count;
		// Function for recursively counting files within a directory
			get_recursive_file_count = function(target_dir, entry_list){
				file_count = 0;
					if(type === "dir"){
						result_count = get_recursive_file_count(sub_target_dir, sub_file_list);
						file_count++;
				return file_count;
Used like this:
		dir = new Dir( 'your_path_to_directory' );
			file_list = dir.entryList("*", Dir.Files|Dir.Dirs|Dir.NoDotAndDotDot, Dir.Name);
			count = get_recursive_file_count(prop.target_url, file_list);
Improved to fix some bugs and controlling search depth:
			get_recursive_file_count = function(target_dir, entry_list, search_depth, file_count, iteration){
				if(typeof(file_count) == "undefined"){
					file_count = 0;
				if(typeof(iteration) == "undefined"){
					iteration = 0;
				if(iteration == search_depth){
					return file_count;
				iteration++;
					if(type === "dir"){
						result_count = get_recursive_file_count(sub_target_dir, sub_file_list, search_depth, file_count, iteration);
						file_count += result_count;
						file_count++;
				return file_count;
		count = get_recursive_file_count(prop.target_url, file_list, prop.search_depth);
And here is the fixed byte count:
			get_recursive_byte_count = function(target_dir, entry_list, search_depth, byte_count, iteration){
				if(typeof(byte_count) == "undefined"){
					byte_count = 0;
					iteration = 0;
					return byte_count;
				iteration++;
					if(type === "dir"){
						result_size = get_recursive_byte_count(sub_target_dir, sub_file_list, search_depth, byte_count, iteration);
						byte_count += result_size;
				return byte_count;
