Hi Andrei,
There was a problem with transparency flattening in the communication between PitStop Server and Switch which required a change on both PitStop Server and Switch. PitStop Server received the change in version 10, update 3 and Switch will receive it in version 11. This means that PitStop Server 10, update 3 doesn't understand the transparency flattening command that Switch 10, update 3 gives.
I would advise you to go back to PitStop Server 10, update 2. This version will work fine in combination with Switch 10, update 3. I'll send you the direct download links via PM.
Kind Regards,
Jonas
