Please Help!
I have a script that works great when ran manually. I want to use it in a switch flow. This script creates Tifs from adjustment layers in the open document. Is it possible to have all of these new tifs go down the outgoing connection? I've tried to convert this but I don't know what in the hell I'm doing...
________________________________________________________________________
// thanks to xbytor for regexp;
// 2012, use it at your own risk;
#target photoshop
if (app.documents.length > 0) {
var myDoc = app.activeDocument;
var docName = myDoc.name;
try {var basename = docName.match(/(.*).[^.]+$/)[1];
var docPath = myDoc.path}
catch (e) {var basename = docName;
var docPath = "~/Desktop"};
// try to get set »Main colors« in »product«;
try {
var theSet = myDoc.layers.getByName("group").layers.getByName("colors");
for (var n = 0; n < theSet.layers.length; n++) {
theSet.layers[n].visible = false;
// process;
for (var m = 0; m < theSet.layers.length; m++) {
var thisLayer = theSet.layers[m];
thisLayer.visible = true;
var layerName = thisLayer.name;
while (layerName.indexOf("/") != -1) {layerName = layerName.replace("/", "_")};
saveFlattenedTiff (myDoc, basename + "_" + layerName, docPath)
thisLayer.visible = false;
catch (e) {alert ("can’t locate folder")};
////// function to save the flattened tiff from copy //////
function saveFlattenedTiff (myDoc, basename, docPath) {
tifOpts = new TiffSaveOptions();
tifOpts.embedColorProfile = true;
tifOpts.imageCompression = TIFFEncoding.TIFFLZW;
tifOpts.alphaChannels = false;
tifOpts.byteOrder = ByteOrder.MACOS;
tifOpts.layers = false;
myDoc.saveAs((new File(docPath+"/"+basename+".tif")),tifOpts,true)
Any help would be greatly appreciated.
JG
Converting Photoshop Script
- TOP CONTRIBUTOR
Hello, try this modified version that adds Switch variables.
var myDoc = $doc;
var basename;
try {
} catch (e) {
$error = "filename error";
try {
// process;
saveFlattenedTiff(myDoc, basename + "_" + layerName)
} catch (e) {
$error = "can’t locate folder";
function saveFlattenedTiff(myDoc, basename) {
myDoc.saveAs((new File($outpath+"/"+basename+".tif")),tifOpts,true);
outfiles.push($outpath+"/"+basename+".tif");
Dwight Kelly
Apago, Inc.
dkelly@apago.com
var myDoc = $doc;
var basename;
try {
} catch (e) {
try {
// process;
} catch (e) {
Dwight Kelly
Apago, Inc.
dkelly@apago.com
- TOP CONTRIBUTOR
Add a "Problem folder" to your flow. It's listed with the other Configurators. Existing jobs will be preserved and show up when you start flow again.
Send me a sample input file if you want me to verify the correct behavior. Your Photoshop script looked for a very specific type of adjustment layers.
Dwight Kelly
Apago, Inc.
dkelly@apago.com
Dwight Kelly
Apago, Inc.
dkelly@apago.com
- TOP CONTRIBUTOR
Here's the version that correctly processed your sample PSD file. Set this a the Photoshop "Save" script in Switch.
var myDoc = $doc;
var basename;
try {
} catch (e) {
try {
// process;
} catch (e) {
myDoc.saveAs((new File($outfolder+"/"+basename+".tif")),tifOpts,true);
$outfiles.push($outfolder+"/"+basename+".tif");
var myDoc = $doc;
var basename;
try {
} catch (e) {
try {
// process;
} catch (e) {
