installed PowerSwitch 10.2 on an brand new MacPro with 10.7.3.
Have now several weird effects:
Message "Server settings notification: Can't find server settings; loading default settings"
Switch trys to update changed configurators on every restart again.
Are there any known issues with 10.7?
Or works it fine?
Kind regards,
Jörg
PowerSwitch 10.2 and 10.7?
Hi Jörg,
Switch 10 is not officially released for Mac OS X 10.7 (Lion).
The first compliant version is the new Switch 11.
The problems you experience result from the fact that Apple change the permissions of the /Library folder and its sub folders.
Best regards,
Robert
Best regards,
Robert
Joerg Schober
Hi Robert,
thanks.
But ... that means since for month you can't buy new hardware (with 10.7) and use it with switch.
A little slow reaction from enfocus...
Jörg
thanks.
Jörg
- TOP CONTRIBUTOR
I had similar behavior with Switch 10 on 10.6. It would always want to update the configurators on startup. Switch 11 fixed that behavior.
Joerg Schober
And how did you fix that? If i select "Cancel", Switch shuts down.
- TOP CONTRIBUTOR
I just let it update every time.
