Enfocus Community • Job Folder Arrangement date wise
Posted: Wed Mar 01, 2017 3:14 pm
by rakesh kumar
Hello to all,
Hope you all are doing well,
I want to arrange a input job folder in date wise in a folder.
I have a received a Package folder (indd. Link, Fonts, Instruction folder)including it through submit hierarchy and I want to arrange the Package folder with name in a date wise folder.
Re: Job Folder Arrangement date wise
Posted: Wed Mar 01, 2017 3:18 pm
by sander
You mean like you want to put files in e.g. 2017-03-01\inputjob?
Posted: Wed Mar 01, 2017 3:37 pm
by rakesh kumar
Thanks for your response,
Received Input through Submit Hierarchy is ABC_001 Folder and Arrange like
Out put is arrange ABC_001 Folder inside 2017/03/01.
Posted: Wed Mar 01, 2017 3:52 pm
by rakesh kumar
Thanks Sander,
Yes,
You are right.
We Have successfully Create a date folder using set hierarchy but when the job folder moved in Date folder the Job Folder extract and all files are reached in without job folder.
This is the problem Part.
Posted: Wed Mar 01, 2017 3:57 pm
by sander
Try this flow:
Flow itself: https://we.tl/jAyMjSkfgA
Required settings;
Submit hierarchy
Set hierarchy path.
I'm on Windows, so I can't test with / in a folder, I used - instead.
[Switch.Date:Format="yyyy-MM-dd",TimeZone="System"]
Archive hierarchy + folder result;
Posted: Fri Mar 03, 2017 6:37 am
by rakesh kumar
Hi Sander,
Hope you are well,
Really Thanks for your valuable support to solve that problem.
Right now I am unable to test it but hope it will work, when I Back I'll test and revert.
Again Thanks for help.
Rakesh
Posted: Fri Mar 03, 2017 11:57 am
by sander
You're welcome man, let me know if you have any more issues ;)
