SQL Statement works in build window but parse error in define window
cwswitch
Here is my code - I'm looking for jobs with "outwork" that do not fit certain criteria.
SELECT Factor FROM OutworkInput
WHERE EstimateID =(SELECT EstimateID FROM MainJobDetails WHERE JobNo = '[Job.NameProper]') AND
Code NOT IN ('LF_FREIGHT_01', 'LF_FREIGHT_02','LF_FREIGHT_03', 'LF_FREIGHT_04','E_INSTALL','DIG_PRO_CLICK')
It returns 1 correctly when I'm in the build SQL window but has a parse error and fails once I OK that window
Displays 1 for the test file with Outwork. Displays "SQL statement executed successfully but returned no value or information" for files with no outwork. - This is what I expect as so in both cases it's executing and working, giving me the value I'm looking for or nothing.
You can see the errors start as soon as I OK. The black non-error message was produced when I was in the build window, the red errors start as soon as I OK.
Subsequently I never receive a 1 so always have a false
enfocus
If there seems to be an issue with the software itself, please report it to Enfocus Support via the support portal:
https://www.enfocus.com/supportportal
If it is the first time you do so, please also mention your Switch maintenance contract number in the case.
sander
Just to mention: Personally I never use the Build SQL statement / manual edit window because it kept crashing my Switch all the time. It made me very aggressive when I started using SQL in Switch :mrgreen:
Does your statement work if you put it in a 'Database connect' configurator or do you get the same parse error then?
Part of my playground:
- HP Indigo 10k, HP Indigo 7600's (full options), Highcon Euclid III, Zünd S3
- HP Production Pro 6.0.1, HP Production Center 2.5.1 beta, Apogee 9.1, Enfocus Switch 13u1 & PitStop Server 13u2.
cwswitch
sander wrote:Does your statement work if you put it in a 'Database connect' configurator or do you get the same parse error then?
woo hoo, yes.
Thanks!
sander
Haha, good to hear!
