Enfocus Community • Adjust the sticky note in the annotated report.
Posted: Thu Jul 13, 2017 10:53 am
by wouter86nl
Is there a way to adjust the text in the Sticky note in the annotated report?
The answer that I could find, closest to the solution is this:
http://www.enfocus.com/manuals/Extra/Cu ... tings.html
But what i want is to customize the text in the "AddSummaryAnnotation".
Preflight resulted in [x] error, [x] warnings.
Click the bookmarks to highlight the problems.
Report for [x].pdf
Preflighted on [x] by Enfocus PitStop Pro 17
Report generated by Enfocus PitStop Pro 17
Could someone help me on this one? Thanks in advance!
Greetz
Re: Adjust the sticky note in the annotated report.
Posted: Tue Jul 25, 2017 6:01 pm
by Padawan
I don't think that's possible. Out of curiosity, what do you want to add? Some "Preflighted By" company info?
Posted: Mon Aug 07, 2017 10:20 am
by bens
You can disable the summary annotation, but you cannot change its text. Only OEM partners have the option of (some) changes to the "Preflighted by" and "Report generated by" sections.
You can also specify whether the summary annotation is open by default, its colour, and some other visual changes. To do this you need to make a copy of the annotated report template, and edit it.
Have a look at this post for extra information: https://forum.enfocus.com/viewtopic.php ... 682&p=6328
