Hi
I want to call a webservice from within Switch Scripter and just pass it a value...the jobname basically.
I managed to be able to call StoredProcedures from within SwitchScripter, which works fantastic.
Does anyone maybe have a sample code that has done this before from within SwitchScripter please?
Just for interest sake, this is how I call the Stored Procedure:
dbStat.execute("rsp_insert_records '" + campaign + "'" + "," + "'" + jobname + "'" + "," + quantity);
dbConn.disconnect();
Call a webservice from switchscripter
- TOP CONTRIBUTOR
Switch only supports SOAP v1 protocol. Most webservices use HTTP/JSON/WDSL protocol now.
Hi
i have this sample to call webserver via SOAP to send mail order:
You have to create SOAP request (url, request, action).
look the manual......
var dataset = job.getDataset('Xml');
var map = dataset.createDefaultMap();
var progressivo = dataset.evalToString ("/field-list/field[tag='myorder']/value", map);
var url = "http://www.mySite.com/sendop.asmx";
var action = "http://soapinterop.org/SendMail";
var request =
"http://soapinterop.org:SendMail" :
"TagsOrder" : "http://soapinterop.org:ID",
"http://soapinterop.org:ID":progressivo} };
var result = SOAP.request(url, request, action);
job.log(1,'Valoreprogressivo='+progressivo)
s.log(-1, "Result: %1",
result[http://soapinterop.org:SendMailResponse][SendMailResult]);
var request =
I am also struggling with the syntax for a SOAP request. I'm trying to connect to a proofHQ API (http://api.proofhq.com/home). The documentation says their entry point is "https://www.proofhq.com/soap". The WSDL is at https://www.proofhq.com/soap?wsdl
I'm trying to perform the method named "doLogin". It requires two parameters: Login, Password
How do you form the request object portion of: SOAP.request(url, request, action).
I'm assuming the url is "https://www.proofhq.com/soap", and based on the WSDL, the action is: "https://www.proofhq.com/doLogin".
Any help in understanding how to form the request object would be greatly appreciated.
Hey Braam,
Can you send me the stored Procedure call as you use it in the Script.
I'm trying to call a stored procedure from an MySQL database...
Thanks,
Peter
Thanks,
Peter
Hi Peter
sure, here is a sample of a entire script...whats important to note though is that you have to create a ODBC connection to the MYSQL database first on the Switch server. then call that ODBC as your database, you cant call the MYSQL database directly.
Thanks for the replies everyone, I will test it and give feedback once I got it working.
Kind Regards
Herewith a entire script Peter:
var ordernumber = job.getNameProper();
dbConn = new DataSource();
dbConn.connect("XMPIESQLPlatLife","plc","plc247");
if ( dbConn.isConnected() )
var len = job.getNameProper().length;
// var campaign = job.getNameProper().left(len - 12);
var campaign = job.getNameProper().left(12);
var jobname = job.getNameProper();
var quantity = job.getNameProper().right(3);
s.log(1,"Database connection succes" + ordernumber + "ja praat" + campaign + " " + jobname + " " + quantity);
dbStat = new Statement(dbConn);
else
s.log(1,"Database connection error");
Kind Regards
else
