Loading multiple files/jobs into a single CLI argument
Posted: Mon Sep 17, 2012 7:37 pm
by kylek23
I need to combine multiple HTML files into a single PDF using Prince XML CLI. Below is the manual CLI I use:
/usr/local/bin/prince /Users/kolbek/Desktop/princeprocessmulti/ABA_TYL_v017n01_at_their_service_outside_counsels_role_in_working_with_large_corporate_clients.html /Users/kolbek/Desktop/princeprocessmulti/ABA_TYL_v017n01_how_can_you_help_promote_national_disability_awareness.html /Users/kolbek/Desktop/princeprocessmulti/ABA_TYL_v017n01_is_the_electoral_college_a_party_school.html /Users/kolbek/Desktop/princeprocessmulti/ABA_TYL_v017n01_the_superiority_requirement_of_rule_23_packs_a_big_punch.html /Users/kolbek/Desktop/princeprocessmulti/ABA_TYL_v017n01_your_duty_to_report_thirdparty_illegal_conduct.html -o /Users/kolbek/Desktop/princeprocessmulti/ABA_TYL_v017n01.pdf
Can calling all the file paths be accomplished through variables or do I need a script?
Posted: Mon Sep 17, 2012 8:58 pm
by dkelly
Are the files in a Switch job folder? If so, you can use this script to set the value of the "Execute command" arg property.
var argStr = "";
var theJobFolder = job.getPath();
if (job.isFolder()) {
var theJobDir = new Dir( theJobFolder );
var theFilesList = theJobDir.entryList( "*", Dir.Files );
for( var index = 0; index < theFilesList.length; index++ ) {
var theFilePath = theJobFolder + "/" + theFilesList[ index ];
argStr.append(""" + theFilePath) + "" ";
} else {
argStr = "%1";
argStr;
Learn advanced Javascript for Switch
Full day seminar during Graph Expo in Chicago, Oct 8th, 2012
http://www.brownpapertickets.com/event/264833
Dwight Kelly
Apago, Inc.
Posted: Mon Sep 17, 2012 10:40 pm
by kylek23
Thanks for the quick reply, Dwight.
I've tried the script in the execute command and as a script element, but I get the following error:
Error in line 12 of script : TypeError. Undefined member function 'append' for object '' of type: 'String'
If it is a script element, will the execute command pickup the normal %1 as the string from the script?
Do I need to worry about the last bit of the argument: "-o "%2""?
Posted: Mon Sep 17, 2012 11:29 pm
by dkelly
var argStr = "";
argStr += (""" + theFilePath) + "" ";
} else {
argStr = "%1";
argStr += " -o %2";
argStr;
Posted: Tue Sep 18, 2012 3:56 pm
by kylek23
I got it to work. It was just missing some escaped quotes and a semicolon. This is great because I can use it for both single and combined jobs.
var argStr = "";
Posted: Tue Sep 18, 2012 5:05 pm
by dkelly
You shouldn't have to quote the substitution variables %1 and %2
