Enfocus Community • Re-fill the checkpoint data in a new checkpoint.
Posted: Thu Oct 11, 2012 9:43 pm
by Flow666
Is it possible to use the field data filled in by a checkpoint, so that i can re-fill a other checkpoint later in the flow with that same data. So if i click the "process" button in SwitchClient the data is already filled in.
I know that it is possible with the combination with a Sumbit Point.
Posted: Fri Oct 12, 2012 4:38 pm
by dkelly
yes, make sure that each Submit Point uses a unique dataset name to avoid having the later one over write the earlier one. Then just set the default value for each metadata variable to retrieve it's value from the previous Submit Point's dataset.
Dwight Kelly
Apago, Inc.
dkelly@apago.com
