Mmoexp POE currency: Positioning and Control
reinebdyfu
Post by reinebdyfu »
5. Positioning and Control
Since the companion is an independent entity, positioning and POE currency control are essential to making the most of its abilities:
Tank Companions: If you're using your companion as a tank, position yourself behind it to let it absorb incoming damage. Make sure the beast engages the enemies first, drawing aggro before you begin attacking.
Offensive Companions: For damage-focused companions, try to keep enemies at a distance where your beast can unleash its full offensive potential. This may involve kite-ing enemies to maintain a safe range while your companion does the heavy lifting.
Keeping Safe: If your companion is more fragile, position yourself and your companion so that you can protect it from POE 2 Currency dangerous enemies, particularly bosses that might focus on multiple targets.
