Enfocus Community • Barcodes in PSS and SWITCH
Posted: Tue Nov 20, 2012 2:56 pm
by lukpal19
Has anybody tried to add barcodes to pdf?
I have downloaded example flow from crosroads but it seems that barcode which is generated iw wrong and unreadable. Any ideas how we could use any external appplication for generating it?
Is there any chance to add such code to PDF in SWITCH?
Posted: Tue Nov 20, 2012 4:19 pm
by Clive Andrews
Yes - using a Barcode font add custom text via PitStop - you can even make it variable then!
Posted: Wed Nov 21, 2012 9:04 am
by lukpal19
Clive Andrews wrote: Yes - using a Barcode font add custom text via PitStop - you can even make it variable then!
Hi, I have tried using this. U use code128 in PitStop to addText and it generates a barcode. The problem is I can' read this with any barcode erader. If I generate barcode 128 via Internet the code looks diffirent. Can I ask you sen me a generated barcode fro your PitStop in example text 1234. I could compare results then?
Posted: Wed Nov 21, 2012 2:44 pm
by dkelly
Apago is beta testing a barcode reader for Switch. Please contact me if you would like to participate.
Dwight Kelly
Apago, Inc.
dkelly@apago.com
