Enfocus Community • Unexpected movement of annotations
Posted: Thu Jan 17, 2013 12:14 pm
by tkittel
Hello all.
In the switch 11 update 1 reference guide (page 57) I found the following sample script for summary of "annotations":
// Acrobat is used to make a summary of the annotations resulting in a file that shows you
the page
// content and the annotations per page.
// No arguments are required.
if($error == null)
try
var title = $doc.documentFileName + " summary"
$outfile = $outfolder + '/' + $filename + "_summary.pdf";
$doc.ANsummarize($doc, title, ANSB_Page, null, $outfile, null, false, true, false, false,
false, false);
$outfiles.push($outfile);
catch(theError)
$error = theError;
$doc.closeDoc( {bNoSave : true} );
$error
Trying this script using the acrobat configurator (version 1), all annotations in the resulting summary were moved away from their original position. Could somebody confirm this behaviour?
Furthermore I can't find a helpful explanation of the 'summarize' command of the acrobat scripting api. In a forum thread I found:
ANsummarize(doc, title, p, r, dest, fs, print, twoUp, useSeqNum, scale, noAssocDoc, filter, paperWidth, paperHeight)
The values doc, title, dest, print, twoUp, useSeqNum, scale, paperWidth, paperHeight are nearly clear, but p, r, fs, noAssocDoc and filter aren't!
Is there a documentation for this available?
Thanks in advance,
Thomas
OSX 10.6.8, Switch 11 update 1, Acrobat 10.1.1
Posted: Thu Jan 17, 2013 4:04 pm
by dkelly
ANsummarize() is an undocumented API function.
p = sort method (use ANSB_Page to sort by page order)
r = reverse sort order (boolean)
You can also use this loop to print the annotations.
this.syncAnnotScan();
var annots = this.getAnnots({ nPage:0, nSortBy: ANSB_Page });
for (var i = 0; i < annots.length; i++) {
console.println(util.printf("%s,%s,%s", annots.author, annots.type, annots.contents));
Another option is to use PDFspy to dump the annotations (and lots more) :-)
Dwight Kelly
dkelly@apago.com
Apago, Inc.
Posted: Fri Jan 18, 2013 2:53 pm
by tkittel
Hello Dwight,
thank you for your explanations and your code. I'll try this next week. So there's no official API function from Adobe to summarize comments with Acrobat - neighter with javascript nor applescript?
Okay, I see: I've to speak once more with my boss about your software "and lots more" ;o)
Have a nice weekend,
Thomas
