Enfocus Community • JavaScript
JavaScript
Posted: Tue Feb 22, 2011 9:58 am
by agaetano
i need a javascript reference manual to work with FullSwitch. For example now i would like to create a flow that add a WaterMark using a precise rules, i tested this example but don't work.
doc.addWatermarkFromFile({
cDIPath: "c:Tacca.pdf",
nSourcePage: 1,
nEnd: 5,
nHorizAlign: 0,
nVertAlign: 0,
nHorizValue: 0,
nVertValue: 0,
nRotation: 0
JavaScript
Posted: Tue Feb 22, 2011 5:00 pm
by dkelly
Hello, what tool did you want to use to perform the watermarking? Acrobat, Apago, callas, Enfocus, etc?
Based on the function name in your original question I assume you want to use Acrobat Javascript API.
JavaScript
Posted: Tue Feb 22, 2011 6:14 pm
by agaetano
Yes i would like to use Acrobat JavaScript, i need to write a script to use in Save option in Acrobat module. I must to use Watermark only in specified pages for example in 1, 5, 9 , ecc.
do you know another solution?
JavaScript
Posted: Tue Feb 22, 2011 9:43 pm
by dkelly
So the Javascript for Acrobat Professional would be something like:
if ($error == null) {
try {
$doc.addWatermarkFromFile({
nSourcePage: 1,
nEnd: 5,
nHorizAlign: 0,
nVertAlign: 0,
nHorizValue: 0,
nVertValue: 0,
nRotation: 0 });
catch(theError) {
$error = theError;
$doc.closeDoc( {bNoSave : true} );
