With the lack of ability to call another script from within a script, we had to read the script from a file then execute it using "eval".
However, if the syntax is bad, it would lead to a crash of Script Executor.
Could you fix that by making it only throw exceptions instead?
This is quite important.
Thanks!
Please make eval less evil
I can reproduce the fact that SwitchScriptExecutor crashes when there is a syntax error in the string you are sending through eval. I have logged this.
In my experiment I defined a function, but that function is not available after eval, only directly executable Javascript code works.
Now, I thought you would be using this external script for storing interesting functions that you are using all the time and that you do not want to duplicate in the different scripts you are writing. But as that cannot work this leads me to ask what it is you are doing with the external scripts and if there is really a compelling reason for working this way? I would like to understand more. Can you please explain?
The crash bug has been fixed, so it will be in Switch 11 update 4.
I remain curious as to why you are using the external scripts., though.
- TOP CONTRIBUTOR
Maybe they built a library of frequently used routines?
That is also what I thought (see my first reply), but I did an experiment and eval works fine when the string contains directly executable Javascript. However, when you define a function in the string, eval "works" (i.e. no complaints, no crashes), but the function is not available to your code after the eval. This means that the use case of a library of frequently used routines is not possible.
So, either I am doing something wrong, in which case I would like to know what, or marbledaemon is using this eval method for something else, and in that case I am curious what it is, so I can judge whether it makes sense, or whether a different approach is more appropriate.
I was moved out of our workflow team for a while. Now let me come back with the answer.
I used 'eval javascript' in order to achieve what we don't have in Power Switch: include / import libraries and dynamic scripts.
I created a generic workflow which accepted customer files in various and dynamic locations, which in turn were not predetermined at the moment of flow deployment. So basically, different configurations (in form of xml) can be provided to the flow dynamically (run-time) without the need of stopping the workflow (proven to be highly unpredictable). Moreover, the scripts to process of the customer job files can be added, modified and removed dynamically in the same way (by modifying the configuration files). It helps us avoid the need to stop the processing of PowerSwitch every time we add / modify a script.
So as you might guess, all provided pieces of javascript need to be executed by "eval" in our main flow script.
I hope it clarifies
Regards!
I hope it clarifies
Regards!
