Automator flow
marcdeblanck
I would like to pass the original path of a file to an AppleScript via PowerSwtich, so that i can act on the original file
Kind Regards
Marc de Blanck
Hello, you can't pass arguments, like the filename of the original(s), to an Automator. Switch simply passes the input files to Automator as a Finder selection.
You could create a wrapper AppleScript (or Javascript) that calls your Automator script.
marcdeblanck
I could use an AppleScript Script Element, but i can't find how to get the Job Hierarchy
mostly i use JavaScript to get things done in Switch
Kind Regards
Marc
marcdeblanck
nevermind
i found an old example i used with an AppleScript srcipt element
Thanks anyway
