Enfocus Community • Find and Replace text
Posted: Wed Apr 10, 2013 4:27 pm
by phorsley
We are running a trial version of Pitstop Server 11 to test, we currently have Pitstop Server 8.
Is it possible in 11 to set up a hot folder to run a Find and Replace Text.
We know we can do this in Pitstop Pro 11 on a one by one basis but we have 1000's of PDFs to do.
Also when we tried this in Pitstop Pro 11 if the text line wasn't a complete line i.e. the line was split into words then the find and replace would not recognise the 3 three words we are trying to replace.
thanks in advance
Paul
Posted: Wed Apr 10, 2013 5:33 pm
It is not possible to do this with an action list. Would not that be a bit dangerous? What sort of text changes do you want to do?
There is a feature in 11 to "Merge into text lines". This will attempt to recreate several chunks of text into a single line. This works pretty well, but because of the way PDF stores text this has its limitations. For example, when there is a font change on a line the line will not be "reconstituted".
Posted: Wed Apr 10, 2013 5:44 pm
by phorsley
It would be replacing the words "Financial Services Authority" with Financial Conduct Authority" which appears on the back cover of all documents. we cant shorten the the words otherwise it would affect to much other text in the document.
Not knowing Pitstop Server 11, is there no option to set up a merge text lines then find and replace text.
thanks for your help
Paul
Posted: Wed Apr 10, 2013 8:55 pm
It is easy to make an action list with just two actions:
Select text segments
That will do the merging into text lines, but there are no actions with which you can do a find and replace. You can select text containing a certain string, but that is it.
Posted: Fri Apr 19, 2013 6:34 am
by mattbeals
www.iceni.com , look for infix.
Works astonishingly well.
Posted: Mon Apr 22, 2013 6:24 pm
by dkelly
Apago has a tool, pdfmodtext, that can search and replace text in PDF files. One of our customers, Hallmark Cards, uses it to reprice and change "Made in" text on their greeting cards.
We have a Switch configurator available for pdfmodtext.
Dwight Kelly
dkelly@apago.com
