Differences in JavaScript between ExtendScript (Adobe) and Switch
tbiagiotti
Post by tbiagiotti »
I have this script working wonderfully in ExtendScript, and I am very new at trying to code for Switch. Could somebody help me in the translation between the two? Thanks in advance for your help.
It fixes an issue we have with JLYT files for HP Indigo.
Here is the ExtendScript version...
myFolder = new Folder("/Volumes/AUTOMAN/0_Print_Automation/JLYTs/1_In");
folderContents = myFolder.getFiles("*.jlt");
fileCount = folderContents.length;
for (i=0; i<fileCount; i++) {
someFile = File(folderContents);
someFile.encoding = "BINARY";
someFile.open('r');
var foo = someFile.read();
someFile.close();
var find = "/Fl /Cyclic" + String.fromCharCode(10) + "/Ft";
var regex = new RegExp(find, "g");
chgText = foo.replace(regex,"/Fl /Empty " + String.fromCharCode(10) + "/Ft");
someFile.open('w');
someFile.write(chgText);
someFile.close();
destFolder = new Folder("/Volumes/AUTOMAN/0_Print_Automation/JLYTs/2_Press");
destFile = destFolder + "/" + someFile.name;
someFile.copy (destFile);
someFile.remove();
Post by dkelly »
var myFolder = new Dir("/Users/dkelly/Desktop/1_In"); ///Volumes/AUTOMAN/0_Print_Automation/JLYTs/1_In");
var folderContents = myFolder.entryList("*.jlt", Dir.Files, Dir.Name);
var fileCount = folderContents.length;
for (var i=0; i<fileCount; i++) {
var fileName = myFolder.path + "/" + folderContents;
var foo = File.readByteArray(fileName);
var chgText = foo.toString("UTF-8").replace(regex,"/Fl /Empty " + String.fromCharCode(10) + "/Ft");
foo = new ByteArray(chgText, "UTF-8");
File.writeByteArray(fileName, foo);
Dwight Kelly
Apago, Inc.
