Question about XML in the PDF file.
bobogan
Post by bobogan »
Hy all,
At first, sorry for my poor English language, I'm better in French :-)
Here is my problem.
I have 2 pdf, the first without XML inside, and the second with XML inside.
I want to use the XML of the second PDF to the first PDF.
Is it possible ???
Thanks.
Post by dkelly »
Hello, by XML do you mean XMP? If so, do you want to copy the document-level XMP from one PDF to another? Or metadata attached to an element such as an image?
bobogan
Post by bobogan »
Hello, yes I want to say XMP, metadata attached to one PDF to inject to the second PDF.
Thanks.
