Hello all,
I've asked this question to Freddy. But i think he's busy now. so he didn't answer my question yet.
After that, i thought to ask my question to the forum.
I'd like to read a line of text or word from inside of a txt to doc file to manage and direct it from a flow in Switch. Last training in Enfocus, Freddy has told me that i con do it with readLine file class' Member Text I/O functions. And i did something with this function. And i've got something with my poor scripting knowledge. As a result, my script doesn't give me a line of text but it shows the font information from the txt file. i have this result using with log. And you ken see the attached screenshot of my Switch scripter window. and the code itself.
At that point, i need some advice how can get the text inside of a txt file which is written inside of it.
For instance:
if the txt or doc file include the text like this:
Muharrem ALTINTAS
WIT Dünya Bilisim Teknolojileri
Te: +902122702052
I would like to read the first line of the text "Muharrem ALTINTAS" with readLine function.
I wrote this script to do this.
var dosya = job.getPath();
var oku = new File(dosya);
oku.open(File.ReadOnly);
oku.readLine();
var satir = oku.readLine();
s.log(1,satir);
oku.close();
when run this script, info gives me this information: " {fonttblf0fswissfcharset0 Helvetica;} "
I didn't have chance to take the text line that i want to.
I'm sure, i'm missing something in this scripting code but i don't aware of it yet.
Could you share your opinions with me? Or you may advice a different way to have this information.
Here is the screenshot of my Switch Scripter window:
http://img62.imageshack.us/img62/9920/r9l9.jpg
Kind Regards..
Reading line of text from inside of a txt or doc file by a script
here's a good start on how to cleanup an RTF file to get to the raw text lines:
http://webcheatsheet.com/php/reading_th ... om_rtf.php
PS: remove the following line from your script:
oku.readLine();
that one does nothing...
oku.readLine();
muharremaltintas
Hi tz8,
Thank you for your advice. I'll try it.
muharremaltintas
Hi tz8,
After having your link for cleaning text from rtf file. I thought that i can get the text line like "plain text". So, i applied my script to plain text and it worked as expected.
Thank you again for the link that explains cleaning text from rtf file.
http://img819.imageshack.us/img819/5631/g331.jpg
Have a nice evening..
