File rename add Suffix with Autonumber
PBMY_Vincent
Post by PBMY_Vincent »
Hi all,
I can't figure out how to add a filename suffix that have auto number. For example :
Before:
Job0001.pdf
Job0203.pdf
Job1902.pdf
Job0055.pdf
Job0204.pdf
Job2000.pdf
Job3455.pdf
Job5666.pdf
After:
Job0001@1.pdf
Job0203@2.pdf
Job1902@3.pdf
Job0055@4.pdf
Job0204@5.pdf
Job2000@6.pdf
Job3455@1.pdf
Job5666@2.pdf
The number need to start from 1 till 6 then start from 1 again. Until it reach the 30th file (we use "Assemble Job" to hold 30 files per batch / folder).
Why we need to do this though, is to have "Impose Downward" style imposition.
Each file we have pre sorted that, each PDF will have 40 Pages.
To perform the imposition, we had set up a Impostrip Hotfolder, with balanced section setting. And the layout have 6 sections.
Now what we lack is to add these special suffix, and let impostrip know which section these files goes to. (@1 goes to section 1, @2 goes to section 2 etc)
I suppose we can use a script expression to "count" the files and insert the digits, but i have no coding background.
Thanks in advance,
Vicnent
Post by dkelly »
I'm sure that a Switch reseller or consultant would be able to develop a custom flow to solve your needs.
Dwight Kelly
dkelly@apago.com
mervinator
Post by mervinator »
Any update on this? I am also into imposition and I find this a very interesting way to automate layouts.
PBMY_Vincent
Nope, we end up commission Apago to write us a custom script & flow to do this.
