Hello all,
	We've been running Switch on 3 Xserves (2 production, 1 Dev) for some time. Its looking like we have to replace one of them due to a CPU issue and Im wondering if anyone else out there also uses Macs to run Switch and if so any new installs in the last few months ?
	Choice is down to a MacMini with SSDs or my preference being a MacPro which I would think would be more grunty, as we not only run Switch but also Claro and Callas on the same box.
	Any thoughts or suggestions appreciated !
	Regards
	Mitch
						Switch Hardware question - which Mac to use ?
				MitchSharpe
- TOP CONTRIBUTOR
Mac Mini with 16GB RAM and OWC Mercury EXTREME Pro 6G SSD runs Switch really well.
MacPro 3,1 with 8 GB RAM – runs
But I think, it depends on your needs/throughput.
Switch 12 seems to tun faster than 11.
I don't think you are going to find a Mini with enough CPU's to support everything. I think you'd have to go with a Mac Pro. A mini with SSD's would be a screamer though. How many concurrent processes do you run now? That will be the deciding factor.
				MitchSharpe
Thanks guys ...
This is what Im getting after your ( and local Switch rep ) input ...
Mac Pro 3.5GHz 6-core E5
32Gb ram
512Gb PCIe Flash "drive"
Dual D300 2Gb Graphics card
Now I just hope it runs 10.8.5, cause I still want to use Sw 11 U 5 ...
Mitch
32Gb ram
Mitch
Doubtful. Maybe in a VMWare/VirtualBox VM it could.
				MitchSharpe
Thanks Matt ...
Will look into a VM ... should be do-able, I mean most of our Enterprise infrastructure is all VM these days ...
Mitch
Mitch
