Hi out there!
We have:
several ad-layouts (single-page PDFs in colour, serving as a frame) and several article-compositions (single-page PDFs in grayscale).
We need to overlay the basic frame-layouts with the article-compositions.
In numbers: if we have 3 frame-layouts and 10 article-compositions, we expect to get 30 resulting PDFs out of SWITCH.
our equipment:
SWITCH 11
PitStopServer 11
Callas pdftoolbox 6
(I know, not the most recent stuff, but even with the 12 and 7-versions we can’t find a feature for our need).
As far as I can see, there is no feature in Pitstop to overlay files (without copy/paste).
In Callas pdftoolbox I found a predefined overlay-action.
But I didn’t get it to point the action to pick up a file from a folder and not using a specific file (which is working perfectly). I would like to avoid to always change the overlay-file manually.
Any clues?
Any hints about using variables/scripting with this action?
Any ideas for other functionalities possible with our equipment?
Should the SWITCH-client be involved, and if so, how?
Any help is appreciated
Martyn
How to automate overlaying two PDFs in SWITCH/PitStop/CallasToolbox
MartynNitschmann
Did so, Dwight.
But this thread didn’t answer my question.
I’ve tried the Overlay-action with my toolbox.
And it works as expected for specific files.
If I would like to change the overlay-file, I have to go to
SWITCH-->stopping overlay workflow-->pdftoolbox-element (i.e. the overlay-action)-->change the overlay-PDF manually-->restarting overlay workflow
That is not an option to do this manually.
What I ask for is, how to tell the action to look into a specific folder for a file to overlay.
If I change the pdf-file (always different names!) in there, I get new composites whenever I have a new incoming job.
I can’t get the variable in the action to use a pdf from a folder, only a specific file.
It seems to be my inability to put a usable path-declaration in there.
Martyn
Martyn
- TOP CONTRIBUTOR
The "Overlay-PDF" properties has 4 types. Instead of selecting "choose file" select "define single-line text with variables" and then select a switch or metadata variable to change which PDF is overlaid.
