So I have been working on a script that will pull old job folders from several directories based on the job number passed from switch. Everything is working great, but I ran into a snag. Some of the folders are named with a "_Customer Name" and some are not. The script works as is should for the folders WITHOUT the "_customer Name" but fails to retrieve the folders WITH "_Customer Name".
	What I Assume I should do is get a directory of each path (var locObj[] ) then do a match against my job Number. but, i can not for the life of me figure out how to get a directory out of javascript.
	Or, Am i over thinking it?
	Attached is the current script
		//Total Number of Locations//
		var NumberOfLocations = 22;
		//Location Paths//
		var LocObj = [];
		LocObj['Location1']= "/Volumes/prep_files/Jobs/";
		LocObj['Location2']= "/Volumes/prepress_files/Archived Jobs/• Xitron_Backups/";
		LocObj['Location3']= "/Volumes/prepress_files/Archived Jobs/• Prinergy_Backups/1016001 - 1017000/";
		LocObj['Location4']= "/Volumes/prepress_files/Archived Jobs/• Prinergy_Backups/1015001 - 1016000/";
		LocObj['Location5']= "/Volumes/prepress_files/Archived Jobs/• Prinergy_Backups/1014001 - 1015000/";
		LocObj['Location6']= "/Volumes/prepress_files/Archived Jobs/• Prinergy_Backups/1013001 - 1014000/";
		LocObj['Location7']= "/Volumes/prepress_files/Archived Jobs/• Prinergy_Backups/1012001 - 1013000/";
		LocObj['Location8']= "/Volumes/prepress_files/Archived Jobs/• Prinergy_Backups/1011001 - 1012000/";
		LocObj['Location9']= "/Volumes/prepress_files/Archived Jobs/• Prinergy_Backups/1010001 - 1011000/";
		LocObj['Location10']= "/Volumes/prepress_files/Archived Jobs/• Prinergy_Backups/1009001 - 1010000/";
		LocObj['Location11']= "/Volumes/prepress_files/Archived Jobs/• Prinergy_Backups/1008001 - 1009000/";
		LocObj['Location12']= "/Volumes/prepress_files/Archived Jobs/• Prinergy_Backups/1007001 - 1008000/";
		LocObj['Location13']= "/Volumes/prepress_files/Archived Jobs/• Prinergy_Backups/1006001 - 1007000/";
		LocObj['Location14']= "/Volumes/prepress_files/Archived Jobs/• Prinergy_Backups/1005001 - 1006000/";
		LocObj['Location15']= "/Volumes/prepress_files/Archived Jobs/• Prinergy_Backups/1004001 - 1005000/";
		LocObj['Location16']= "/Volumes/prepress_files/Archived Jobs/• Prinergy_Backups/1003001 - 1004000/";
		LocObj['Location17']= "/Volumes/prepress_files/Archived Jobs/• Prinergy_Backups/1002001 - 1003000/";
		LocObj['Location18']= "/Volumes/prepress_files/Archived Jobs/• Prinergy_Backups/1001001 - 1002000/";
		LocObj['Location19']= "/Volumes/prepress_files/Archived Jobs/• Prinergy_Backups/1000000 - 1001000/";
		LocObj['Location20']= "/Volumes/prepress_files/Archived Jobs/• Prinergy_Backups/500000 (Online Orders)/";
		LocObj['Location21']= "/Volumes/prepress_files/DONTUSE/"
		LocObj['Location22']= "/Volumes/prepress_files/Transfer/• Prepress/Prepress_Files_Programs/Switch Backup/NoJob";
		// Switch metadata with history number//
		var JobNumber = job.getVariableAsString('[Metadata.Text:Path="/field-list/field[2]/field-list/field/value",Dataset="Submit",Model="XML"]');
		//I have no Idea what this is its from fred//
		var theSourcePath = job.createPathWithName( JobNumber );
		//Counter for loop//
		var Counter = 1;
		 // location path test: True=nofile False=FileFound
		var Empty = "True";
		//Loop and search locations for history number//
		while(Empty == "True")
			var shortcut = LocObj['Location'+Counter+'']
			//var path = Location1+Counter;
			var folderName = shortcut+JobNumber;
			s.log(1,folderName);
			if (File.exists(folderName))
			 	Empty = "False";
	   		 	s.copy( folderName, theSourcePath );
	    		 	job.sendToSingle( theSourcePath );
	    		 	job.sendToNull( job.getPath() );
		     	s.log(1,JobNumber);
			  //Break loop is no files are found//
			 else if(Counter == NumberOfLocations)
				var theSourcePath = job.createPathWithName( "NoJob" );
				var folderName = shortcut;
	    			s.log(1,"Folder " + folderName + " does not exist");
				Empty = "False";
			 else
		 			Counter++;
						File Directory in Javascript
 - TOP CONTRIBUTOR
var theDir = new Dir("/directoryname");
var theEntries = theDir.entryList("*", Dir.Files, Dir.Name);
for (var i=0; i<theEntries.length; i++) {
var fileName = theDir.absPath + "/" + theEntries;
 - TOP CONTRIBUTOR
This script expression will return all of the subdirectory names in "/Server/files" directory.
var theDir = new Dir("/Server/files");
var theEntries = theDir.entryList("*", Dir.Dirs, Dir.Name);
var list = new Array;
for (var i = 0; i < theEntries.length; i++) {
if (theEntries == '.' || theEntries == "..")
continue;
list.push(theEntries);
list;
Dwight Kelly
Apago, Inc.
Switch reseller and script developer
continue;
list;
Dwight Kelly
Apago, Inc.
Thanks for the help.
Attached is the script for future reference to anyone who might need it.
//Location Paths//
var LocObj = [];
LocObj['Location22']= "/Volumes/prepress_files/Transfer/• Prepress/Prepress_Files_Programs/SwitchBackup/NoJob";
//Define Regual Expresion
var Counter = 1;
var Empty = "True";
//Create Directory of files
var theDir = new Dir(LocObj['Location'+Counter+'']);
var theEntries = theDir.entryList("*");
var longFolderName='';
var needle = JobNumber;
var re = new RegExp(needle, "g");
for(var i=0; i<theEntries.length;i++){
var folder = theEntries;
if(folder.match(re))
longFolderName+=theEntries;
if (longFolderName != "")
Empty = "False";
var folderName = shortcut+longFolderName;
s.log(1,longFolderName);
Empty = "False";
else
Counter++;
//Location Paths//
var LocObj = [];
var Counter = 1;
var Empty = "True";
Empty = "False";
Empty = "False";
else
Counter++;
dkelly wrote: This script expression will return all of the subdirectory names in "/Server/files" directory.
Dwight Kelly
Apago, Inc.
var theEntries = theDir.entryList("*", Dir.Dirs|Dir.NoDotAndDotDot, Dir.Name);
list;
i shortened your code to get rid of this "." and ".." test which is not needed when using the Dir.NoDotAndDotDot filter
Cheers,
Thorsten
						Dwight Kelly
Apago, Inc.
list;
Cheers,
Thorsten
