Enfocus Community • Switch integrated with Prinergy
Posted: Thu May 29, 2014 10:54 am
by arothenberger
Good morning,
There is a YouTube video showing the integration with Switch and Prinergy. Does anyone know the person that posted this? I would like to view the flow in more detail, in regards to generating a Prinergy XML file.
Best Regards,
Adam
Posted: Thu May 29, 2014 3:11 pm
by dkelly
Andrea Mahoney, Automated Workflow Developer @ Tribay Enterprise in Ontario, Canada
Posted: Wed Jun 11, 2014 10:14 pm
by Evan
Hi Arothenberger,
You need to have RBA (Rules-Based automation) installed with your Prinergy. Then you use an event or manual trigger with the action "Write Text to File" to make an XML. Your XML can contain all variable of prinergy needed like job name or a folder to pickup.
In Switch you can associate a folder made by Prinergy with the XML you just have create with "XML Pickup'. The XML will be store in a dataset that you can use later to drive back your files.
If you don't have RBA with your Prinergy you can create a folder named as your job and use that name to put back your files in the right directory or job hotfolder using "Archive hierarchy" configurator in Switch.
Re: Switch integrated with Prinergy
Posted: Wed Nov 11, 2015 6:27 pm
by giuliana.dusi
Hi to all.
it's possible to have the link of this video to see how this flow works?
Giuliana
Posted: Thu Nov 12, 2015 8:23 am
by pietdepauw
It's indeed on our YouTube channel, however it is no longer listed.
This URL will take you there: https://www.youtube.com/watch?v=26ARqv_IB4I
