removing clipping masks
hello, i have a problem with a file that i have. its a file containing lots of images that are masked. i need to remove a mask OUTSIDE of the crop box but retain the masks WITHIN the crop box. can this be done? the file is about 200 pages. i was thinking maybe select all out side masks and delete but there seems to be no action for that. thanks in advance for any and all help.
- TOP CONTRIBUTOR
Have you tried "Select objects outside region" with "Select objects" set to "outside region" and "Select clipping paths" checked?
dkelly wrote: Have you tried "Select objects outside region" with "Select objects" set to "outside region" and "Select clipping paths" checked?
thank you for the help. i dont seem to be able to find the "Select objects outside region" in the actions list.
ok, i figured it out! thanks for all the help dkelly. i appreciate it.
